hash check error, hanging message header
Anyone seeing these?
Selected posts: 1
Total parts: 1
Available parts: 1 (100%)
Parts with bodies: 1 (100%)
Subject: A "small" request. ^_^
Author: Msb (kneel@myfeet.now)
Date: Thu, Jan 12 11:56
Message-ID: <43c68a26$0$1564$c3e8da3@news.astraweb.com> (has body)
Replies: ( <7t9es117ddrjrqe296143eh09tgscrjbi3@4ax.com> ( <hehfs11balv4snluol1a706an48tb9kca4@4ax.com> ) )
Newsgroup: AsianDVD (regular, compact binary)
Dests: All newsgroup servers (compact binary newsgroup)
The header in question 'hangs' in the newsgroup folder with a check mark on it and is impossible to remove short of a restart.
It occurs when I double-click a header to view the text/attachment and then double click it in the message window to display it in the viewer. Once I have finished/exited the message window. The header remains in the newsgroup display with a check (and red) and is not removable.
Not a terrible problem, but frustrating
Selected posts: 1
Total parts: 1
Let me work on it some more and get back,,,,,,, but;
The delete/purge action is subsequent to the problem (as I see it). It is the check mark remaining in the download column on a message which has already been downloaded and read. (red).
It just hangs there and an integrity check will produce the hash error message. It occurs when I double-click the article to read it (small attachment), and then double click the icon in the message display to view it, then exit the message display window back to the newsgroup/folder window.
Back later with more if needed.
try to describe the sequence i need to invoke to see that (check in edit menu->fonts&colors what the "red" color means, in case you customized colors, it doesn't affect anything thougy, is it "read" in your setup?).
the delete/purging is preceding the problem, what means "subsequent" (i'm sorry if i missed something with my english )?
Yes, RED is READ
Subsequent = After the fact/problem.
Here with more info: (sorry for the long text)
Sequence of events:
1. Run diagnostics/integrity, receive SUCCESS! Open a newsgroup/folder.
2. Double click on post with attachment (AVI Sample)
3. message display window opens immediately, and shows an icon for my external
player for the AVI.
4. Double click the icon and it brings up the player (this particular AVI did NOT
play but produced an error in the player)
5. Exit the player, and exit the message display window (Click the X)
6. The post header shows a check mark on the box to the left (selected for download)
7. The post header shows read (red).
8. Check mark will NOT GO AWAY, Properties printout for the post is as below:
Selected posts: 1
Total parts: 25
Available parts: 25 (100%)
Parts with bodies: 25 (100%)
Subject: [2657]-[#altbin@EFNet]-[FULL]-[ The.Corpse.Bride.WS.DVDRiP.XViD-DEiTY ]-[64/66] - "tcb.sample.dvdrip.xvid-deity.avi" yEnc (*/25)
Author: digitL@treadstone.gov (digitL)
Date: Tue, Jan 17 22:14
Partial: Total: 25; Available: all; Bodies: all.
Parts:
Part: (1/25) Message-ID: <Qoizf.32134$g8.29226@fe62.usenetserver.com> (has body)
Newsgroup: Divx (regular, compact binary)
Part: (2/25) Message-ID: <5pizf.32139$g8.18121@fe62.usenetserver.com> (has body)
Part: (3/25) Message-ID: <npizf.32143$g8.24331@fe62.usenetserver.com> (has body)
Part: (4/25) Message-ID: <Epizf.32147$g8.24313@fe62.usenetserver.com> (has body)
Part: (5/25) Message-ID: <Wpizf.32151$g8.21552@fe62.usenetserver.com> (has body)
Part: (6/25) Message-ID: <9qizf.32156$g8.1783@fe62.usenetserver.com> (has body)
Part: (7/25) Message-ID: <mqizf.32159$g8.7548@fe62.usenetserver.com> (has body)
Part: (8/25) Message-ID: <Aqizf.32162$g8.28592@fe62.usenetserver.com> (has body)
Part: (9/25) Message-ID: <Oqizf.32165$g8.27007@fe62.usenetserver.com> (has body)
Part: (10/25) Message-ID: <%qizf.32168$g8.15158@fe62.usenetserver.com> (has body)
Part: (11/25) Message-ID: <arizf.32171$g8.20749@fe62.usenetserver.com> (has body)
Part: (12/25) Message-ID: <jrizf.32173$g8.19224@fe62.usenetserver.com> (has body)
Part: (13/25) Message-ID: <srizf.32175$g8.24913@fe62.usenetserver.com> (has body)
Part: (14/25) Message-ID: <Brizf.32177$g8.25391@fe62.usenetserver.com> (has body)
Part: (15/25) Message-ID: <Krizf.32179$g8.551@fe62.usenetserver.com> (has body)
Part: (16/25) Message-ID: <Trizf.32181$g8.31457@fe62.usenetserver.com> (has body)
Part: (17/25) Message-ID: <0sizf.32183$g8.14246@fe62.usenetserver.com> (has body)
Part: (18/25) Message-ID: <8sizf.32185$g8.6759@fe62.usenetserver.com> (has body)
Part: (19/25) Message-ID: <isizf.32187$g8.26979@fe62.usenetserver.com> (has body)
Part: (20/25) Message-ID: <rsizf.32189$g8.12538@fe62.usenetserver.com> (has body)
Part: (21/25) Message-ID: <Asizf.32191$g8.16395@fe62.usenetserver.com> (has body)
Part: (22/25) Message-ID: <Gsizf.32193$g8.32123@fe62.usenetserver.com> (has body)
Part: (23/25) Message-ID: <Lsizf.32194$g8.87@fe62.usenetserver.com> (has body)
Part: (24/25) Message-ID: <Qsizf.32195$g8.3436@fe62.usenetserver.com> (has body)
Part: (25/25) Message-ID: <Usizf.32196$g8.12227@fe62.usenetserver.com> (has body)
9. Run Diagnostics/integrity check and obtain the following results:
Hash check error: partial invalid flag partial 00A080AA
Selected posts: 1
Total parts: 25
Parts:
10. Pull out some of remaining hair and send this message
11. The post/header in question is a "fly-on-the-wall" for the remainder of
the UE run (until restarted), It can not be Unchecked/Purged/Deleted.
That's it
Sequence of events:
player for the AVI.
Selected posts: 1
Total parts: 25
Parts:
Selected posts: 1
Total parts: 25
Parts:
That's it
but according to properties all parts have bodies.
here what i see it just finishes download and put the "body" green notepad-like icon, no check mark, it doesn't depend what i do in the article view.
can you create another instance with a single relatively small newsgroup e.g. alt.binaries.e-book.technical (use e.g. properties->general->change database folder, then copy reg.dat and flt.dat to the new database location to have the same settings since i suspect it is something specific to your settings), delete all other newsgroups and leave only this one.
just be careful not to delete your original databse.
do you see the same problem?
Setup as you suggested:
1. alt.binaries.e-book.technical, got new headers (default setup of newsgroup).
2. Select header indicated below (A larger PAR2)
3. Double click it, and observe the message display window with the QuickPar icon.
4. Right click the icon and select view in editor.
5. View it an exit editor.
6. Exit message display window.
7. Damn thing shows Read (red), with a check mark on top of the green box.
(note the PAR2 was NOT saved).
That's what I get. I have the 'normal' batch of programs running, Outlook Express,
"I hate Spam", Total Commander, and AVG.
What do you think?
Hash check error: partial invalid flag partial 005EE5ED
Selected posts: 1
Total parts: 4
Available parts: 4 (100%)
Parts with bodies: 4 (100%)
Subject: Kelvin Varley Divider Explanation Kelvin Varley Divider Theory.pdf.vol15+16.PAR2 (*/4)
Author: <someone@somedomain.com.invalid>
Date: Mon, Jan 16 02:42
Partial: Total: 4; Available: all; Bodies: all.
Parts:
Part: (1/4) Message-ID: <43cb4e19$0$3375$e4fe514c@dreader26.news.xs4all.nl> (has body)
Newsgroup: alt.binaries.e-book.technical (regular, compact binary)
Part: (2/4) Message-ID: <43cb4e4b$0$3375$e4fe514c@dreader26.news.xs4all.nl> (has body)
Part: (3/4) Message-ID: <43cb4e7d$0$3375$e4fe514c@dreader26.news.xs4all.nl> (has body)
Part: (4/4) Message-ID: <43cb4eaf$0$3375$e4fe514c@dreader26.news.xs4all.nl> (has body)
What do you think?
Selected posts: 1
Total parts: 4
Parts:
can you invoke edit menu->clear history, also you may remove server passwords (i can put my servers instead) then .rar the database and email it to support at usenetopia dot com, i'll check it here, maybe something in your settings. you may even email me only reg.dat from the new database directory, it will be very small email then.
