Feature request
Bert
Feature request
Post by Bert »
I would like to see an option in properties to limit the number of days when doing an index search. I always see many results of more than 30 days old but I never can download them, so i rather not see them at all.
I know i can put it in in the searchbar, but then I have to do this each time i do a search. I'd rather see a checkbox where I can set the max number of days back. The serverload will be less too.
it doesn't reset the number of days from search to search within one session but maybe it should preserve the field from session to session or indeed to add it into properties, right now it is the topmost entry in the days combo box upon program restart, the simplest solution would be just to fill in the last value.
Bert
Post by Bert »
Preserving the field from session to session looks like the best and simplest solution. No separate option needed then.
