Download and paused
Leechmonkey
Download and paused
Post by Leechmonkey »
Alex,
I can't seem to find it but is it possible to Download with paused priority? Basically, I use this feature once in a while if I'm waiting for a thread to finish but I want to remember and I dont use flags much since I have to unflag it.
Also, like today, I was having problems with Newshosting so I'd like to queue up some binaries but not download them yet.
you can use "download later" range of article priorities.
tasks menu->suspend articles marked for later download + "download later"
in principle i could also add "download paused", the problem here it would almost double download options: download, download&save, download auto, download with priority, download&save with priority, download later, download immediately etc it is applicable everywhere, it could be some toolbar button though to make all download options "paused" at the moment.
Leechmonkey
No worries, I'll just use the task on the menu bar to keep it clean and simple. I'd rather not have UE's context menu be 200 lines long :)
