Save dialog with history
jonib
Post by jonib »
Hi
What I think would make the save dialog complete is a dropdown list with previous save paths.
I was hoping the new Explorer dialog would work with PowerDesk Dialog Helper that keeps track of opend folders and files but no luck.
Right now I prefer the custom save dialog.
yes i think it is a good idea, but it will be only possible in the "explorer" and "custom" dialog since the edit box in them is mine and they are based on the same class.
"custom" i wrote myself the two others are hacks.
