Cleanup UE
Contrabanda3365
Cleanup UE
Post by Contrabanda3365 »
Alex,
How can I cleanup UE databases?
Gr.
Gonzales
in fact there is no reason to do that.
if you want to perform full cleanup outside the program - exit the program and in the database directory delete everything except for the settings directory. then on restart invoke for the "newsgroups" entry in the workspace context menu -> advanced -> reset header ranges.
then if it matters edit menu->clear history.
