As I say: when I view a message by double clicking a header in a binary group, and I return to the header window by clicking Escape, I have to scroll the window in order to find that selected header again. This is a bit of a nuisance.
I seem to remember this was not so in earlier versions. Or is it me or has something changed?
Main window (header window) has shifted after viewing a msg
Regards, Hubert
It is not the case of getting new headers. I can repeat the problem as often as I want.
How can I give you an example? Maybe a more detailed description.
I have the group alt.binaries.sounds.music.classical opened and the new headers are displayed. I activate Show threads, Show collections and Show files. The header window for the sake of demonstration is made narrow enough for the scroll bar to be present. I scroll to the bottom and choose a message there (1). Get the message by doubleclick (2) and go back with Escape (3).
Then the window has scrolled up and the selected header is not visible any more.
I put the 3 screenshots in "alt.binaries.test" with header "UE-screenshots" for you to see if you want.
Regards, Hubert
