where are my downloads going
mossey
Post by mossey »
My downloaded rar and par files always used to be saved to my download folder. Now, all of a sudden they don't appear there. If I click on a rar in the import view they appear to be there. I did a search of the PC but can't find where they are located - so I can't unrar them etc.
Any ideas?
Mo.
If you're able to view them in Import then you probably haven't saved them, although it's possible to save and not delete headers/bodies.
Another possibility is that you've accidentally clicked the Suspend saves button. Check to see if File->Default toolbar->Suspend save queue is selected. You'll be able to tell if saves are suspended by the existence of articles in the Save tab in Task Manager.
Did you download and save your articles or just download them?
mossey
thanks a million
Post by mossey »
Sorry I took so long in replying but I'm just back from my holidays. Your suggestion was spot on - I had selected the suspend and save option.
Thanks again.
Mossey.
