autosave incompletes
If I use "download and save attachments" all files are saved but not the incompletes. Can I change that inside the settings?
as far as i remember in newspro incompletes are not saved automatically, but in usenet explorer (including unlimited trial for newspro registered users) they do.
also in usenet explorer is an option to delete incomplete bodies after save but i don't remember whether the option already was in the unlimited trial.
unlimited UE trial covers most newspro options and as to reliability it is the same as the current UE version (and UE has higer database fault tolerance than newspro), the main difference the current UE version has collections but collections don't exist in newspro. interface is similar just all works many times faster consuming many times less memory under heavy load.
