Quitting in middle of download and save?
aberly
Post by aberly »
Suppose you have a cue going that is downloading and saving attachments. But you need to shut off your computer. What is the best way to handle this?
Start->Shutdown... :wink:
UE will close normally and next time you run it the queue will pick up from where it left off. There might possibly be a situation where, for instance, UE is saving a massive file and the OS tries to kill it where there could be problems. It depends on how you set up your system. I have mine to kill processes in five seconds rather than wait the full length before it does it. The OS will treat processes that report as 'Not responding' as candidates for killing. I occasionally see UE doing this as I'm switching windows but if you let it finish its operation things will resume as normal.
aberly
Post by aberly »
Thanks. I'll give it a try.
