Very Happy
However, I am extremely frustrated with it (UE 1.7.3) continually telling me "All tasks suspended because less than 48mb is available on the database drive" (my wording of this popup error message is not exact, by the way, but that is the gist of it). I am on day 2 (I think) of the trial.
What happened is that I imported a number of NZB files, left the settings at their default (many, if not most, settings in the properties dialog are NOT intuitive, unfortunately). I come back to my pc after sleeping thru the night (over 8 hours, and the time estimated in UE's status bar said 6h plus some minutes), and what do I find? It has been stopped for perhaps 6 hours because there is no more room on the database drive. When I investigate why this is happening, I find that I have over 16 GIGABYTES of headers (or are they bodies? or articles? Every newsreader calls them something different! AARGH! AAAARRRRGGGHHH!).
Before going to bed, I made certain that there was enough room on the download locations for all my selected files to fit. I even used the "Save Path" context command to change the location of 8 gigs of files so that they were saved on another drive. However, nothing at all ended up getting saved under those folders, in fact, not even anywhere on any of the computer's hard drives. They are ALL still in the BODIES folder!!!!
The "Bodies" directory structure is setup like this (in the Bodies folder), along with the sizes:
Code: Select all
E:\UE
\Bodies
\0
2A 663,471 bytes
2B 663,520 bytes
2C
2D
2E
2F
3A
3B
3C 83,912 bytes
3CB
3CC
3CD <etc>
AC7
AC8
AC9
AD
AE
AF
B0
B1
B2 <etc>
B3
E:\UE\Bodies\1
2A 663,040 bytes
2B 663,320 "
2C
2D
2E
2F
3A
3B
3C
3D
3E
3F
<etc>
<Nearly 2000 of the same type of cryptic filenames as seen in folder "0">
E:\UE\Bodies\2
E:\UE\Bodies\3
E:\UE\Bodies\4
E:\UE\Bodies\5
E:\UE\Bodies\6
<ETC>
E:\UE\Bodies\7
E:\UE\Bodies\8
E:\UE\Bodies\9
E:\UE\Bodies\A
E:\UE\Bodies\B
E:\UE\Bodies\C
E:\UE\Bodies\D
E:\UE\Bodies\E
E:\UE\Bodies\F
Why isn't UE decoding and combining these files as soon as the bodies are downloaded? It hardly ever seems to do this, instead it downloads the bodies from my selected articles, and never combines them, so subsequently my hard drive runs out of room! I had the tasks set to the default of 40. That was before going to sleep last night. Today, i changed it to 3. I am also frustrated that there are no detailed help files available to explain how these settings in the Properties dialog affect the running of this whole program. I don't understand the purpose of this Tasks being set to "40".
Back to the lack of a comprehensive help file: The Usenet Explorer site has only a very basic help section. It does NOT explain the settings/properties at all. I have searched and searched and searched. By the way, 15 days is not long enough for a trial run on this program. At least, without an incredibly detailed help text, it will take at least 15 days to learn the basics!!
I apologize for being so down on the program in this situation, but I am extremely frustrated. I am looking for a newsreader/binary downloader that will work without me having to troubleshoot it for hours. This seems to be the one, IF I can soon understand how all the configurations affect each aspect of UE.
Please shed some enlightenment on this situation! I searched the forum for any info on this exact problem, but came up blank. There were somewhat similar issues, but none that seemed quite the same.
Oh, I have read the b4e tutorial on using UE. It is still too general. So are the ones at http://www.netwu.com/ue/seltopics.htm ("seltopics.htm" = "Selected Topics" : are there additional topics somewhere?).javascript:emoticon(':?:')
Question
javascript:emoticon(':idea:')
IdeaSome suggestions:
1. Add lots more popup tool tips over icons, such as in the "Workspace" area. The four icons at the bottom of this section are hard to figure out.
2. The purpose of each of the tabs at the bottom of the Task Manager are also difficult to intuitively figure out:
Code: Select all
Article | Console | Downloads | Articles | <icon> | <a question mark icon> | Save | headers | <icon> | <a question mark icon> | Newsgroup list | <icon> | <a question mark icon> | POsts | <icon> | <a question mark icon>
What is the relationship of all these tabs above? What are they each used for (in some detail, please)?
3. Need ability to pause specific items in the download queue, or in the save queue, not a "pause whole program".[/color]
I hope you can shed some light on the BODIES issue, and hopefully, these other issues too.
