Search failed. Too many users, please try later. ??
RDC
Post by RDC »
Today's the the first time I've gotten this error while trying to search: "Search failed. Too many users, please try later. "
It seems that even if I wait minutes there are still too many users.
Anybody else got this error message too? Or might know a solution?
Thanks for your time.
augurk
Post by augurk »
I got it too and i dont like it :x
jercro
Post by jercro »
Same here. First time.
jd
Post by jd »
Also right now.... Very strange. It's happening since a couple of days. I wonder is it really because of "Too many users"?
jercro
Post by jercro »
Was OK last night. And seems to be working this morning OK.
Expect a server glitch.
RDC
Post by RDC »
Been away a few days, but it all seems to work again. I'm happy again. :)
yes, i know, those messages are shown here in the server control panel, this is not a problem with server workings.
i need to add a simple modification to avoid those messages, i sorted out other things here, i'll do it shortly and get here back when it has been done.
i added a little code and restarted the server with the changes, but the problem didn't happen for two weeks or so, when it does (or when there are signs without this actually happening) then i can take effective measures to prevent it from reoccuring.
no problem with the server itself, in short it is a kind of inadvertent user abuse.
based on my observations the problem has been taken care of as to prior external causes, i'll add more refined code later as a matter of precaution, need a client release since need to return new error message in a certain case to prevent such an issue.
i did some more work on the topic as i planned, while i'm writing this - the server is being restarted with more changes, i have now much better understanding of how to deal with the issue at the root.
jercro
Post by jercro »
Alex
Seems to be working Ok over here for now. Thanks
i finished the rest of the work, should be enough for now, so i won't bother people with server restarts.
