Cannot find server or DNS error (UE:20002)
Paladin
Post by Paladin »
Hi, just FYI; I have been getting a lot of errors using the search as of late.
This has been on and off for over a week. I cannot remember it may be longer. I usually try again later and it works but it has been down more than up.
I get the error:
Search Failed
EDIE: Nope, I am still getting this at times.
check your firewall, maybe it blocks dns requests.
you may try to put the server ip instead of the server name directly into properties->general->search/import, find ip e.g. through resolving the server name through some online dns resolver, the ip didn't change for a year so it is pretty invariable, but it may change since formally it is not a static ip.
e.g. use
http://network-tools.com
you can verify there the dns is resolved properly.
wendoxin
Re: Cannot find server or DNS error (UE:20002)
Post by wendoxin »
Why they keep DNS server and Mail client Server is placed outside the intranet of a company? Is there any particular reason to place the DNS server and Mail client Server outside of a company what would be a validate of the above problem?
______________________________
yahoo keyword tool ~ overture ~ traffic estimator ~ adwords traffic estimator
Terry
Re:
Post by Terry »
Right now I'm getting a lot of DNS errors.
8 out of 10 times I get the DNS error. I didn't change any firewall setting in between searches.
alex wrote:you may try to put the server ip instead of the server name directly into properties->general->search/import, find ip e.g. through resolving the server name through some online dns resolver, the ip didn't change for a year so it is pretty invariable, but it may change since formally it is not a static IP.
Alex, is that option still available in v4.4?
Code: Select all
Client:       Usenet Explorer v4.9.3 - 64 bit (registered)
OS:           Window 7 Ultimate  - 64 bit
Anti Virus:   Avast Premium - 64 bit (updated daily)
Firewall:     Avast Premium - 64 bit (updated daily)
Usenet:       Eweka
Normally it should work, I don't experience problems searching from 3 completely different locations and servers have search counters which more or less the same, so it doesn't appear that particular server location is affected.
There may be an issue with routing from your location to one search service location, look what server number it shows in the error message if random numbers only in one range of those two: (1) to (4) / (5) to (9) this is likely the case.
Terry
Post by Terry »
It's not a structural problem but sometimes the error pops up often for an hour.
If it's really a proble with a DNS server entering the IP may be the easy solution.
Code: Select all
Usenet:       Eweka
look at the number it shows it in parentheses.
e.g.
Search failed (2)
Search failed (5)
if the number is only in one of those two ranges 1 to 4 or 5 to 9 it may be some routing problem not related to your setup. if you see numbers in both ranges e.g. when you make searches you see one time (3) and another time (7) it is probably something on your side.
