posting: error 20024; what does it mean
bassie
Post by bassie »
I am posting something now.
And during the post i get a message: Read error (UE: 20024).
"Failed 1" is also noted
Is not a problem, because the post goes on from that time.
But maybe i can prevent this error? Maybe it's because i am also downloading the same time?
bassie
Post by bassie »
During the post more errors occur.
I am using Vista.
Maybe its because i am doing more things at the same time? I stopped downloading with UE, so its only posting.
But maybe other activities like playing music etc. might disturb the reading speed from the hard disc or so?
bassie
Post by bassie »
it looks ok when i rightclick and use "retry". Then at the end everything is posted.
i don't know try to check the file system for errors, read error should mean the program cannot read a file.
try whether you can reproduce the error message by posting the same file into alt.binaries.test
other activities don't matter, posting doesn't depend on other kinds of tasks.
