How to change server address in existing server?
cumonin
Post by cumonin »
Hi!
It's possible I'm just too blind to see where it is, but I can't find where to change the server address of an existing server (in properties there's only fields for port, username, etc.). Is it actually possible to change the address and if so, where?
The reason I'm asking is because I found a faster server (within the same newsgroup provider) to change to and want to keep the download count.
Thanks!
/cumonin
NoNo
Post by NoNo »
it's easy; just invoke "Advanced"->"Rename" instead of "Properties F4" while right-clicking on the server.
cumonin
Post by cumonin »
Wow, there you go, it was right there and I couldn't see it :)
Thanks for the quick reply!
/cumonin
