It is a very good program, so now I'm hoping ill get the key quickly cause the trial will run out in two days
The question is i dont wanna loose all the data in the trial so can I picup where I left off by just extracting the registerd UE into the same map registering when i start up and go further with the registered version or is there something more complicated to be done.
JR
