Hi Alex,
Is there any future considerations towards a 64 bit version of Usenet Explorer
Comments and Thoughts everyone ...
Thanks.
64 bit version ?
the code is compileable in 64 bit, i just don't distribute such compilation since it doesn't make practical sense, the speed is the same. there are problems with x64 to get error log information though when such a version is running, i didn't find similar code as i'm using for 32 bit, it doesn't work in x64.
i'm only using 64 bit compilation for indexing server since it needs more than 3GB RAM which is the ultimate limit in win32 systems, it is the same project/source code as ue.
