Autonaming of folders
Marek
Post by Marek »
Is it possible to set the autonaming of files so that it uses the fist filename minus the file extention instead of the whole subject line where it cuts off the excess text.
I tend to keep all my downloads in folders so i have to manually rename all the folder names or make new ones which takes time.
Im just wondering if there is a way to speed up the process
can you give a straightforward example with some specific subject, like what is now versus what you would like it to be, i'm just will be working on a different topic, so maybe you now have a better idea than me.
Marek
Post by Marek »
Well for example:
(????) [08/22] - FTD 410522 - "Oceans 13 HD Trailer 1080p.part06.rar" yEnc (*/24)
then i ALT + D on that header and i get the result of the download creating a folder with the downloaded contents as such ( with my current settings ):
( ) [08-22] - FTD 410522 - Oceans 13 HD Trailer 1080p.part06.rar yEnc
For what i was asking about is that it would be nice if it just used the name of the file in the "FileName" and used just that info to create a folder for the downloads.
An extra nice touch would be to omit all the file extentions at the end of the file name.
I guess this would be depending on how ppl have their posting agent set up but more often than not i see all file names contained inside of " "
another example:
header info:
SEARCH: #altbinaries.tv presents: Burn.Notice.S01E06.DSR.XviD-P00PFAKT0R [*/34] - "Burn.Notice.S01E06.DSR.XviD-P00PFAKT0R"
Folder info:
#altbinaries.tv presents Burn.Notice.S01E06.DSR.XviD-P00PFAKT0R [16-34] - burn.notice.s01e06.dsr.xvid-p00pf
My idea:
jaapf
Post by jaapf »
Similar question, but slightly different.
I know it is now possible to rename a collection after it's imported (or made from headers). Would it be possible to automatically rename the save path as well?
