Hi Alex,
I found this issue that is easily reproducible.
I'm not using any firewall or anti-virus and I believe it's only related to ue (1.9.9).
First you need a filter, thou it does work with an initial filter.
Just create a simple one like "partest" where "subject contains .par2".
Open a newsgroup or folder, apply the "partest" filter, tick "Expand threads/collections" and tick "Show files" to off.
Now you should notice in the newsgroup/folder window that the keyboard arrows are ineffective on non-expanded threads/collections and the shift selection too, depending on how many threads are still expanded.
The "Shift+delete" function will delete a thread but will not disappear from the window.
The "Expand thread/collections" and "Collapse" will work on some thread but not others...
After some testing, I think this behavior only happen with a filter while" Show files" is off and you play with the quick filter state button or text or expand/collapse.
The "Show files off" and filter issue
got it fixed here, just the kind of optimization i was using from precollection code didn't work in this case, so i put a more generic function instead, measured how long it takes - it was the same so no big deal.
added also proxy for search service, maybe there is enough material for a small release (i'm updating v1.99 code in parallel with larger work when any issues are reported).
