Combining post bodies
Tiggy626
Post by Tiggy626 »
How do I combine two (or more) posts? I have 2 headers for the same file, one with the icon that shows the top half grayed out and the bottom half green, and one with the icon that shows the top half red and the bottom half green. Is there a way to combine these two things?
Please let me know if you need more information.
Thanks,
Tiggy
Save each part separately then either use 'copy /b' at a command prompt or a simpler/easier way is to use something like Bl Join.
It sounds like the post you've downloaded was badly formed. Is there no way to get the article elsewhere? Check the filename and use it in UE's search service. That would be the simplest method of all to resolve the problem.
