"Explore" default directory.
swent
Post by swent »
How about a change from "Open" to "Explore" for default save folder toolbar button? I don't use the "Open Default" button, as the collections are in subdirectories, and it's easier to use explore" than it is to open the default and then navigate to each subdirectory. It would be more convenient to access all collections directly from the client. It's a minor inconvenience, but one that occurs often.
in the next release there will be "shell" combo box in general properties near right bottom, you'll be able to choose between "open" and "explore"
