Hello,
Is there a way to pause the unpacking/repearing of UE2.0?
If not, is'nt it something to think about? (or a kind of low process/thread priority setting)
When I have a lot in the que it can happen that UE starts repairing and unpacking and when I want to burn a DVD the buffer goes empty and the writing speed goes to zero (buffer underun protection).
But I'm glad to see that UE is getting a good al in one solution. Keep up the good work.
Erwin
Pause unpacking
Ah, that I did'nt see that, stupid of me.
Then I hope that there is (coming) something to give UE a lower proces priority while unpacking
I used to unpack with a program that is called AutoUnpack and that has a option like this so I can burn and unpack at once.
Any way, thank you, although it the menu was clearly visible I did not see it.
Erwin
Erwin
