I got a "Repair: Verify failed error", but with Quickpar.exe everything repaired without any errors (and then I could unppack ofcourse).
It happened when I was downloading "RMB.2008.Pal.Retail.CCE9.DVD5.AnotherW@yTeam" from alt.binaries.u4e and I was playing GRID online during the download.
do you get repeated error or single error on the same set? if single and repeated try has succeeded on the same set, you've never had problems with RAM on that computer?
are you sure the files were not repaired by quickpar and then you ran UE on them, since it would lead to verify error as well, since files shouldn't change in between downloading and repairing (if they changed you need to readd them in UE manually "add files").
Single error I think. I mean, I didn't see any retries.
No problems with RAM before.
And yes, I am sure I didn't use Quickpar.
So there was a verify error and with good reason, because then I used Quickpar that repaired the files.
I think too (like dengle suggested) that playing Grid (a very recent game) caused the error.
it doesn't make sense, but i downloaded that post, indeed repair was needed, it repaired without errors.
if you see such an error try to invoke repair manually again, verify failed still means the par2 set remains in the repairable condition.
ue is more likely to expose any RAM or memory bus problems because of the way it operates, the result is the file operations are much faster than in quickpar, in the next release CPU usage will be same or faster than quickpar as well, so the total repair time will be faster.
