This seems like such a simple question, but I can't figure out how to edit, change, or rearrange the newsgroup columns (e.g. Subject | Author | Age | Lines | Size). Also, is there a way to change the Age Column so it displays absolute Date ?
T
How do I edit the columns in the newsgroup view
Re: How do I edit the columns in the newsgroup view
You can change the size of the columns by dragging the line between column headers and rearrange by dragging the header title to a different place.askance wrote:This seems like such a simple question, but I can't figure out how to edit, change, or rearrange the newsgroup columns (e.g. Subject | Author | Age | Lines | Size).
I don't think you can add or remove columns, but you can hide a column by making it as small as possible.
And the settings are saved per newsgroup view.
Menu->Edit->Show dates / age.Also, is there a way to change the Age Column so it displays absolute Date ?
jonib
