How Do I Recover > Delete Headers & Threads?
I thought I was finished with em but saw something I wanted but the rest was gone. I know there is a way to reload but I can't remember. TIA
you can check "del" in the quick filter bar to see deleted headers as well.
by default when you check "del" also "^del" (^ means negation, i.e. not deleted headers) is checked, so when you initially check del both deleted and not deleted headers will be shown, then you can uncheck "^del" to see only deleted headers.
you can select deleted headers and invoke "undelete" from the context menu or its advanced submenu, or if you mark them for download for example they will be undeleted automatically.
