Newsgroup list updated again
I've updated newsgroup list. It appears the newsgroup list remains almost unchanged, so I will just update the list at periods less than header feed server retention, so all headers in new newsgroups will be included, unless someone will point to a missing new newsgroup, then I can do an immediate bulk update, it is fast anyway.
intravenus
Post by intravenus »
alt.binaries.movies.bones can this group be added ? I can download files via Giganews but not Astraweb.
cheers
dracula
Post by dracula »
intravenus wrote:alt.binaries.movies.bones can this group be added ? I can download files via Giganews but not Astraweb.
cheers
You must ask on Astraweb to add the newsgroup.
i can bulk update newsgroup list again.
as to this particular newsgroup - i see it is on highwinds but not on astraweb, it has 14 movie posts all at all in the last 4 days and one text post 63 days ago (maybe it was created back then).
astraweb you can ask them to add it.
i'll try to make the bulk update within few days, it is safer than to add one by one.
intravenus
alt.binaries.movies.bones....has this been added to the search yet ? TIA
the update will be a bit later, there were some deep changes in the client code towards the next release which kept me busy, i want to recompile the server, check it is still ok, then to update the list, i'm not sure about this particular group, i just download the whole newsgroup list and refresh the newsgroup list on all server instances. the work on the client is almost finished, so it won't take long, at worst within one week.
ok, i've updated the server executable, looks ok, i'll update newsgroup list a bit later, it may involve some downtime to preserve complete headers in added groups.
intravenus
ok thanks for the update
done
intravenus
alt.binaries.teevee can this group be added ?
TIA
ok i've added it now, but take into account from now on i'll update the newsgroup list on monthly basis just before database backup, it is somewhat safer to ensure databases are in sync and right groups go into right places. if it is urgent, though, i can add one by one as well.
intravenus
ok...thanks for that
intravenus
alt.binaries.movies.bones Not able to search this group now...was fine 20 minutes ago or so. Looks like it's been omitted in the last update/restart
yes router fell, so i restarted it in the backup configuration, but not completely right.
router is now on, i'll restart it in the full mode.
intravenus
working now..thanks :)
