Mishap and abort error
Luciole
Post by Luciole »
Hi
Some download work great
For some other ones, I got this "Mishap" error and Abort message (No file on the server).
But even if I renew my search, there are still in the list.
Any clue why ?
Cheers
Luciole
UE search uses several usenet servers as header feeds, it is possible your server not as complete as they are in total, the same applies if you use nzb files. if you see those files in UE search but they are not on your server, it only can mean your server is incomplete.
you can rely on unpack feature which provides automatic par2 repair (if the error is "423 no such article" or generally the error code is 423, just message is different no file on the server or whatever UE can handle it seamlessly through "ignore no such article errors" option in properties->save/unpack->save which is checked by default).
or if server is too incomplete and it is commercial server you can change provider (see pm).
