default save folder when opening NZB file
ticatc3
Post by ticatc3 »
When i open an NZB file it always saves the attachements on the UE\downloads instead of my preferred folder defined under "save/unpack". How can i change it?
edit menu->properties->newsgroups.
if you only want to define the folder for nzb file, select the import group, then in the bottom there is "Save:" group of controls, press browse and select the save folder.
in save/unpack you can only define unrar folder, if it is relative - it will be relative to the save folder you set in properties->newsgroups.
the reason it is there because you can define it on per group/folder basis, if you want a single save folder define it for the topmost "Default" entry and leave the rest Save: Default.
ticatc3
Post by ticatc3 »
Thanks!
