Still a little new here, just trying to automate as much as I can.
I am able to save attachments in the directories I want and UE automatically starts up collecting new headers, (killing the bad boys) but I find I still have to select the headers then right click and choose Download&saveAttachments.
Is there any way I can have all the headers selected automatically then start Download&saveAttachments?
Oh yes I noticed delete probable duplicates can I get that in there too?
Thanks for a fine product Alex.
Auto Pilot?
if you want to download all headers in the group and save all attachmetns - you can create a filter which matches all headers in the filter editor (edit menu->filter editor) e.g. "subject contains *", watch and wildmat check boxes checked.
then you just add the filter in edit menu->properties->watch/auto.
it is described here:
http://www.netwu.com/ue/help/filters.htm
delete probable dublicates i remember is relevant only for text posts, UE doesn't remember binary posts which have been downloaded since it would be not precise (files may have the same name and/or same prefix), add more settings and it could also mislead a user if he wants to download the same post again.
