Download something with priority
dito
Post by dito »
How can I download something ahead of the rest?
jonib
Post by jonib »
Sounds like Download with priority is what you're after, when you rightclick on a header go to the advanced submenu, there you will find several priority settings with shortcuts.
Also you can change priority in the taskmanager.
Download immediately (Alt+I) is probably closest to + in BNR2.
Hopefully this was what you ware after.
jonib
