Suspend tasks when disk XXX MB left - on which disk?
ticatc3
Post by ticatc3 »
I have the DB on one disk and the download folder on another. I want to suspend tasks when the download disk is almost full, but i think this setting is for the db disk.
the setting is for the db disk.
as to other drives - the logic is now, when the disk is full - the save queue will be suspended after a file exception, the file which caused the exception won't be removed from the save queue, so no data will be lost.
are you saving to the system drive?
ticatc3
Post by ticatc3 »
I am not saving to the system drive.
The problem is that the save disk which is different than the db disk gets filled up, it is correct that i am not losing data but it causes problems with other things that are located on that disk like outlook pst file.
