Is there a easy or obvious way to Tell that usenet explorer is currently Paused?
I'm a newbie here. I usually use the Menu via Task ---> Pause/slow down network task. Sometimes I use the first menu option, sometimes I'll use the second and Pause for 5 minutes or so.
I see down at the very bottom of the screen a Bandwidth indicator message. But with my internet provider (3rd World country, not reliable) just because the bandwidth is close to 0 -- doesn't always mean that I've asked for a Pause. So is there an Easy or Obvious way for me to tell that Usenet Explorer has been Paused? Thanks in Advance. Robert
Paused - How to Tell?
Re: Paused - How to Tell?
I know of only two places the Task->Pause/Suspend menu's and the Toolbar buttons.warrenrh wrote:Is there a easy or obvious way to Tell that usenet explorer is currently Paused?
jonib
it is also in the system tray menu, you can see there if the button is pressed as well.
to avoid problems - you can use the pause for x minutes option, if you click the small downward arrow you'll see different possible values. the pause option is not persistent, if you restart UE it won't be in the paused mode.
