Custom unpack folder
dracula
Post by dracula »
Hello Alex,
Now i have some time so i shall place it here too. :lol:
Is it possible to have an option in the unpack menu to select a custom folder to extract? I download everything to a single folder an extract everything in another map. But sometimes i want to unpack some things in a different folder and than is this the best option.
I already lookt on your website and tried it on this way http://www.netwu.com/ue/help/unpack.htm but it is really too much work sometimes. So hopefully you will consider it. It would really be appreciated. Thanks. :wink:
Do you mean to unrar?
There is an option "derive name after rar", it will work with both absolute and relative folders, just check that box.
Or you can download into a separate folder and to have unrar set to "relative" edit menu->properties->save/unpack, unrar, Rel. (Abs. should be "None").
If to add another option on the top of it I guess everyone else will get confused, it is already 7 controls in the Unrar group control.
dracula
Post by dracula »
Ok i gonna try this and let know if it works. :lol: Thanks.
