I am getting this error message "The server is an alias" and the newsreader cannot get new headers. Connection seems to work fine, and bodies are downloaded without any problem.
Any idea?
The error message means that two of your servers are using the same IP address, probably one of the servers temporarily are using the same IP address as one of your other servers.
If you don't want UE to check for aliases, Uncheck "Check for aliases" in Menu->Edit->Properties->General->Servers
jonib
jonib
