nzbget gives an error such as this:
Code: Select all
/path/to/file.nzb:5: parser error : Input is not proper UTF-8, indicate encoding !
Bytes: 0xED 0x61 0x20 0x31
<file subject="Posteo #001. DÃa 1 de 1. XviD. - Some file.PAR2
FATAL ERROR: Parsing NZB-document /path/to/file.nzb failed!!
But I thought you'd like to know, so you could fix it if you wanted, i.e. it shouldn't be allowed to stick the à in there as a single-byte character.
