Hey,
Anyone know what settings to play with when VyprVPN running? UE drops all bandwidth and goes to 0kb/s when it is on. I use GN accelerator, but I'm not married to it, actually preferred UE settings, but just being lazy, figure kill two birds etc.
VyprVPN and UE
You don't have to use any VPN, just use SSL, the result is the same including encryption strength.
Instead of giganews accelerator you can just have xfeature checked in edit menu -> properties -> general, compressed headers (it is default), if you use giganews accelerator it must be unchecked because of the accelerator bug or limitation.
If vpn is some kind of redirector and UE works without it and doesn't work when it is on, it means some bug in their winsock provider layer handling by their driver, I guess vpn is not associated with giganews accelerator in any way.
