I mark 10GB for download, I then have to switch off the computer after a few hours (ie I go away) before doing that I click on:
1) "File"> "Save all"
2) "File" >"Exit"
I restart the computer later on I start Usenet Explorer again and it carries on downloading. But I have also seen other buttons like the "Pause" button.
What is the best way to make sure Usenet Explorer will restart the queue of files being downloaded when you have to switch off your computer and go away?
Best way to pause downloading?
Re: Best way to pause downloading?
The Pause button is used if you need to pause the download temporarily (or slow it down).malcarada wrote:But I have also seen other buttons like the "Pause" button.
As long as the setting Menu->Edit->Properties->Tasks->Save article task list is checked, just closing UE is enough. It will continue the download where it was at the time of closing.What is the best way to make sure Usenet Explorer will restart the queue of files being downloaded when you have to switch off your computer and go away?
jonib
