Auto UnRar
t-water
Auto UnRar
Post by t-water »
UE has a occasional problem Auto Un-Raring files for me. 90% of the time it will work fine. Other times the files will be completely downloaded and just sit in the Unpack under Task Manager. I right click and Unrar manually and that works ok.
Enable Auto everything is checked under Properties. Just notice under Save/UnPack Limit Ram Usage is set to 30 Mb. Seems pretty small. Anything else I can check?
Running 64 bit UE under Windows 7.
jonib
Re: Auto UnRar
Post by jonib »
Did those RAR files have a .par2 associated? I believe UE needs to verify a RAR or split file before AutoUnRARing or joining.
jonib
