nzb creation from search results?
MilesAhead
Post by MilesAhead »
I searched "create nzb" and "nzb creation" and got some hits that hinted that maybe it would be implemented in the future, but I don't see a setting or menu command.
If it exists please point me in the right direction. Thanks :)
edit: I found an old post that tells how. Got it. :)
"When a woman demands honesty, I just assume she's lying."
- MilesAhead
Re: nzb creation from search results?
I hasn't added it yet, I'm still not sure it is needed and there is some other more important work on the project ongoing.
The fastest way is to import headers first with automatic opening of the import group. The imported headers are selected, so you can just invoke export headers in the advanced submenu in the newsgroup view, so technically you can create nzb with two clicks if you associate two shortcuts with import headers and export headers.
MilesAhead
Thanks alex. What you describe is the instructions I found. Works fine. :)
- MilesAhead
