Headering
The Postman
Headering
Post by The Postman »
Hello Alex i can't headering the newsgroups, i have xsnews as usenetprovider.
grtx The Postman
Re: Headering
try to reset header range (workspace, right click on newsgroup, advanced) or just reset headers if you don't need them.
edit menu->properties->general you may try to uncheck newsgroup, retention quick, some providers don't supply consistent headers.
and some providers may not support headers at all or have it broken, try to contact their support if all fails.
The Postman
Re: Headering
it doesn'twork, i bought the version 3.11 64 bits, the old one works good this is version 1.9.9.8 what is the problem here :?:
Can you help me out Alex.
grtx The Postman.
