Is it possible to create a watch filter based on Subject and Size.. ex
Subject Rango (and) Size 4.5 gb.
it would match the Subject first and then match the Size.
Just curious. Thanks
Watch Filter
Re: Watch Filter
You need to create 3 filters.
First filter: Subject=Rango
Second: Size=4.5 gb
Third filter: Composite=First filter & Second filter
The third filter is the one you then use as the Watch filter.
Look here for an example under Composite filter. More info here in section Permanent filters.
jonib
Second: Size=4.5 gb
jonib
Get Usenet Explorer Automatic Updater here. You want to flatter me?
Re: Watch Filter
Thanks jonib, I created a couple of Composits.jonib wrote:You need to create 3 filters.
Second: Size=4.5 gb
jonib
