I usually get new headers everyday, even when UE is busy downloading articles. In this case though, I'd like the headers to download first before the articles.
On Properties->Tasks, I see there are sliders in the "Relative Chance to Run". I have tried sliding Articles to the left, and Headers to the right, but it doesn't seem to have any effect. (Current settings attached.)
Is there a way to accomplish this?
Thanks!
Roger
Priorty for Downloading Headers
- Contact:
Re: Priorty for Downloading Headers
The box that says Don't start Article task when header task is running I think would do the job for you, it suspends the downlaoding of the task until the headers are finished. Just check it.rhelliwell wrote:Hi,
Thanks!
Roger
