It would be great if there was a keyboard shortcut to "Pause" or "Unpause" a highlighted header in the Task Manager panel. When I'm downloading, I press ALT+S to highlight all related headers, then I go to the Task Manager and locate the PAR files. I manually "Pause" these (to save bandwidth). If they are needed I Unpause, otherwise, I press ESC to delete them.
Also, a shortcut to set the priority would be ideal (or ALT+I maybe?). Sometimes you want to download the nfo first to so you can read it.
Thanks as always
Roger
Feature Request: Keyboard shortcuts in Task Manager
- Contact:
Re: Feature Request: Keyboard shortcuts in Task Manager
UE does not download PAR files unless they're needed, and also automatically removes them from the list when dl complete. So you don't need to do this manually.rhelliwell wrote:then I go to the Task Manager and locate the PAR files. I manually "Pause" these (to save bandwidth). If they are needed I Unpause, otherwise, I press ESC to delete them.
