Cannot export headers
outside
Post by outside »
I am trying to create a nzb file. The documentation tells me I have to right click the selected headers, click advanced and next export. However, when I do that there is no export command. What do I do wrong?
Using 3.3a, had the same problem in 3.1.
Arnold
NoNo
Re: Cannot export headers
Post by NoNo »
From what I can test the export command never appears when invoked in Search service pane and that's about right.
There should be 11 or 12 sections of advanced commands separated by a line. How many do you have?
outside
Post by outside »
Ah, it is the search pane. I tried it in a normal pane and there it is. Is there any way to get the export command in the search pane?
n2mdk
Post by n2mdk »
You need to Import the Search results you want to create the NZB from.
After they are Imported there will be an Export command in the Advanced section.
outside
Post by outside »
Thanks to you all! This works, though I think that exporting from the search pange would have been easier :D .
Regards,
Arnolod
