Search service problem
Ballsha
Post by Ballsha »
Hello...
In first place excuse me, but I don't write/speak English very well...
I'm using the latest software version (3.3). I'm having problems using the search service. Specifically, when I'm looking for some messages, there are no problems. When I select to download, it's OK. But when I look at the target directory, files are different from those marked, they're mixed with the messages that I had selected for download.
I can't fix them with PAR files, because they have a lot of bad fragments, and re-download don't solve the problem.
Thank you for your help, in advance...
Re: Search service problem
There may be any content, the subject doesn't mean what the content is.
Give me an example (here or pm), I could check it out.
