Search Failed(5)
Willie
Search Failed(5)
Post by Willie »
Subject line is title of message.
"A connection attempt failed...." is the body. I have seen various threads with this same time out error. I have been downloading successfully prior to this. Network speed tests are OK. I have performed a telnet successfully to my news server. Web access to my news server (Easy News) works fine. I tried SSL as well and still get the same error.
Just downloaded headers for a newly subscribed group OK. Still new to UE, used to use News Rover some time ago. Search Service status on home page shows running. I had to disable header compression to get started. Is there something I am missing here? I used UE quite constantly over the initial two weeks before registering it. Until now I was very pleased with it. Hoping this is a simple server issue to be resolved soon. Anyone experiencing the same now? Problem started yesterday evening approx. 20:00 09.25.11 PST.
Thanx, eh?? ;-)
Edit - some browsing I figured this should have been in the Search Service forum....Dohhh......anyone with the power can move this to the proper forum??
