For unclear reasons, while downloading files that have been split with QuickPar, the last few files of the series (.par2 files) seem to stall in the queue.
I'm running the latest version of UE on Windows XP 32 bit.
Thanks.
Problem: .par2 files stall in queue
Re: Problem: .par2 files stall in queue
That's a feature, UE will by default download .par2 files only if they are needed for repair. check this help for more info.jimzak wrote:For unclear reasons, while downloading files that have been split with QuickPar, the last few files of the series (.par2 files) seem to stall in the queue.
If you want to change the default behavior, look in Properties->Save/Unpack.
jonib
Get Usenet Explorer Automatic Updater here. You want to flatter me?
