Hi everyone !
I was wondering if you could help me with UE . I want to use 2 servers (one ipv4 , and one ipv6 using ipv4-to-ipv6 tunnel)to download , or maybe one of them .How do i choose which server will be active and which won't ? And is it possible that would be any issue if both servers running with different retentions ?
Thanks for the help .
How to use 2 servers with different retentions
Re: How to use 2 servers with different retentions
There is no problem to use several servers, there are settings in edit menu->properties->servers to set server preferences (order), also you may e.g. set the program to download headers only from one server, but article bodies from all servers. If you want to use only one server at a time you can disable the rest, in the workspace "Servers" panel just select the servers you want to disable and then use the context menu->disable.
Tanks for the help couldn't find it
Use net is it bye bye bittorent!
