Shortcuts
aberly
Shortcuts
Post by aberly »
I can't find this the help docs.
1. It there a keyboard key I can press to view a message, instead of double clicking it. Or an icon I can add the menu that does the same thing.
2. With a message open on the screen, is there a shortcut to view the next or previous messages that have bodies.
Re: Shortcuts
aberly wrote:I can't find this the help docs.
1. the Enter key
2. File menu->navigation->next/previous body (F8/F7 by default you can customize them) in split view or when task manager "Article" tab is selected.
aberly
Re: Shortcuts
Post by aberly »
Thanks. It didn't think to split the window.
