Purging Database files
Cynyster
Post by Cynyster »
I apologize if this has been covered before.
I have been running UE for years now and have had zero issues with the program.
I have a dedicated Terra-byte Drive for this program so space is not an issue.
I would like however to purge some of the database files from a couple of the larger newsgroups like boneless.
The database folder exceeds 20 gigs in size.
I would just like to be able to say get rid of everything before today and have it remember that I already downloaded those headers before today.
Which is the easiest way to accomplish this?
Cynyster
Re: Purging Database files
Post by Cynyster »
:oops:
Ok I figured out my own question after playing around.
Instead of purge I should have been looking for "Catch Up" then use "Compact and Free"
