From time to time I would like to directly change the header ranges. When attaching a new server to a newsgroup, or to download a portion of headers from months ago, my only option is to re-download everything from a server and then try to sort/filter later. This is time consuming and a waste of bandwidth.
So, could there be a way to manually edit the header ranges? Perhaps add this feature to the Header Range Properties context.
Thanks.
